Mazda Trucks \  engine
engine
Mazda Trucks Make Specific
views 195
replies 6
chopedmazda   +1y
will a 626 engine fit in a b2000
chopedmazda   +1y
anyone?
dssur   +1y
yes and no. The distributor comes out the back of the head on a fwd 626. You will need to switch the head or modify your fiewall.
the block will work just fine, although some are only 2 liter. I have a 2 liter in my b2200 though and actually like it better.
chopedmazda   +1y
ya i was looking at putting the 2 liter in it. and it wouldnt be to hard to modify my firewall to make that fit would it
dssur   +1y
I see in your other thread that you were looking for a JDM engine. If you were looking at the FS, you would need to know that
"In 1993 Mazda created a short bore spacing version of the F engine called the
Kyrasis6   +1y
I thought the sportage used the FE block? Not like there is much difference, lol.
jdm customs   +1y
its the fe3n block, i believe its a gas version of the diesel 2.0. it is a 2.0 86x86 bore and stroke like the fe but with different oil return passages for the dohc head design. solomiata has tons of awesome info for interchangeability (real word?) all of the mounting bosses are the same as the b2000 and b2200 and bolts right up to the tranny but you do have to convert it to EFI and DEI as russ-d said
