lookin for two peice drive shaft.
layinframe2200
Edited: 3/3/2008 6:51:57 PM by layinframe2200
i am needing a two peice driveshaft for an 86-93 mazda b- series out of an extra cab. i have some partw that i am willing to trade
societyoutkast's avatar
societyoutkast
i have a single cab one how much longer does it have to be
Ree-Dee
A drive shaft from a long bed should work. The only problem is locating one.
layinframe2200
well what i need a two peice drive shaft for is because i am building a extra cab regular bed. the beds are different from a regular cab to and extra cab. i changed the reg cab that was on the truck to an extra cab and just streched the frame . i have also put a small block chevy in the front. i had a drive shaft made but now i need to modify it to fit the new set up i am goin to be putting in a carrier bearing in the drive line to help keep the drive shaft outta the bottom of the cab. that is why i need a 2 peice driveshaft. so if any body has one please let me know.
layinframe2200
so any mazda guys on here have a extra 2 peice drive shaft layin around. willing to take it off your hands
layedoutb2k (chase)'s avatar
layedoutb2k (chase)
im pretty sure i got one layin around at my shop but ill have to check.
layinframe2200
that would be great. i have got most of the work done on the frame i just need to get the drive shaft installed and rework my front framed horns. when i did the four inch body drop i cut it in the wrong place and made alot of extra work. i did it like 4 years ago and now i know alot better way to do it. let me know what you find. this would be a big peice of my puzzle
layedoutb2k (chase)
i just looked more at your other post and you said you were switching from a reg cab to an ext cab. did you use a ext cab bed because they are different.
layinframe2200
yeah i have always wanted to make a extended cab regular bed. i have not been a big fan of an extended cab bed, dont like how the wheel wells are offset, so i had an extra cab that i body dropped 3 or 4 years ago and set aside. i decided to use it now so i have a little more room.
societyoutkast
i have a single cab shortbed with a two peice u want it man its only got seventy thousand miles on it
