VtecCrx
Originally posted by TwistedMinis
It looks like your bars are parallel to the ground or pointing up when laid out. They should be like that at ride height. Laid out they should be angled down a bit, and full lift they should angle up a bit. That way there is a happy medium with axle movement.
You should probably also ditch the 90 degree pipe bends. They aren't all that strong.
Exactly. Just look at the upper wishbone. Since when it is layed out, it is straight, once it starts to lift it is going to push the axle forward........
