Toyota Trucks \  Pic Reqwest...Toyota clutch movement for bags & 20s
Toyota Trucks Make Specific
views 451
replies 11
following 10
2be1off   +1y
i was wondering if anyone would be able to post pics to show me how to move my clutch master cylinder up out of the way for my 20`s when lay`d out. and any information will help. ...not doin a body drop... thanks
slammedcivicsi   +1y
without a bodydrop I would think it should clear. But if not then just recess it backwards behind the firewall.
2be1off   +1y
it was about an inch away before i started baggin it.
TwistedMinis   +1y
If you're not bodydropping it you can probably get away with swapping the the smaller 79-83 and early 84 clutch master. There are two kinds. One is about 1.5" long, the other is about 7/8" long.
jdozier1279   +1y
cant remember what issue but mini truckin did an artical on relocating the clutch master to under the dash
doulovemins   +1y
check out my old pick up in my profile its on 20s stockfloored and i recessed it into the firewall 2 or 3 inches or so.
2be1off   +1y
how you do your pedalassembly... any other pics
91toylexus   +1y
i wouldnt mind some pictures also.that would be tiiiiiight.
soccorjimmy   +1y
same here. on the ranger with a 225/35/20 tire it is inches away. I snapped the fitting ance already when I hit sides. JIMMY
1lonisn   +1y
I will try to post pics of mine in the next few weeks, using an aftermarket master cylinder and remote resvoir from JEGS. It is mounted backwards under the dash with stock pedal assembly.
