my question is how do i know if my bags will lift the same and not put one side higher then the other? my bag mounts measure the same so should that do it?
weight affects if 1 side is going to hang lower then the other side.. i.e. you being a fatass or your gas tank is on the same side as you.
running dual needle gauges and having the ability to adjust each corner differently really help.. but realistically, you only need to adjust the front, the rear will stay level if the front is.
Low_Smooth_Cool
each corner will require diffrent preasures to have a level ride height
Deranged731
I have a couple of friends that only run 4 valves, and they have some mean fat man lean goin' on!! My buddy Chris has a v-8 in his Nissan, and the tourque will roll the body under hard acceleration. So ya might want to run 8 valves to keep it level...
