hub runout??
gjfent@gmail.com's avatar
hub runout??
gjf's avatar
gjf
Anyone have issues with 88-00 chevy rear hubs having runout? I have the hub surfaces clean and the adapters torqued but the driver side set of wheels wobble slightly. Has anybody run into this?
someotherguy's avatar
someotherguy
You checked the bearings yet?
Richard
gjf's avatar
gjf
There is no play in the bearings. The hubs spin as they should. Tomorrow, I will throw a dial indicator and use shim stock to true the adapter with the hub. I started by wire brushing the hubs wheel mounting surface before installing the adapter to make sure no caked on crude was causing the run out.
