Mini Truckin General \  stainless stell for a fuel cell
views 157
replies 4
following 5
i cut it   +1y
i recently built a fuel cell out of 1/8inch stainless. i got a 4x8 sheet of it for free from work and then one of the welders there welded it up. i turned out extremely nice. ill post pics tommroow. now my questions is, is it ok to build it out of stainless. i know its kinda late considering i already did it but i am curious if it is goin to be ok for gas. at work we run all kinds of chemicals through stainless, except gas and im not expert on stainless. some input would be greatly appreciated!
thaz chris
truck action   +1y
Yes, have run my custom made tank for three years now!!
LowOrange88   +1y
they make stainless steel gas lines. Stainless Steel has good chemical compatibility with pretty much everything, there are exceptions:
302 STAINLESS STEEL (A-K)
Chemical Compatibility
CHEMICAL EFFECT
1-Butene, 2-Ethyl ---------------------------- No Effect
Acetaldehyde --------------------------------- No Effect
Acetamide ------------------------------------ Minor Effect
Acetate Solvents ----------------------------- No Effect
Acetic Acid 100% Boiling --------------------- Severe Effect
Acetic Acid Air Free ------------------------- Severe Effect
Acetic Acid Aerated -------------------------- Severe Effect
Acetic Acid Vapors - 100% (Hot) -------------- Severe Effect
Acetic Acid, 100% Solution ------------------- Severe Effect
Acetic Acid, 30% ----------------------------- Minor Effect
Acetic Acid, 50% ----------------------------- No Effect
Acetic Acid, 50% Boiling --------------------- Severe Effect
Acetic Acid, 80% ----------------------------- Minor Effect
Acetic Acid, 80% Boiling --------------------- Severe Effect
Acetic Acid, Crude --------------------------- Minor Effect
Acetic Acid, Glacial ------------------------- Minor Effect
Acetic Anhydride ----------------------------- Minor Effect
Acetic Anhydride (Boiling) ------------------- No Effect
Acetone -------------------------------------- No Effect
Acetone Cyanohydrin -------------------------- Minor Effect
Acetonitrile (Methyl Cyanide) ---------------- No Effect
Acetophenone --------------------------------- No Effect
Acetyl Acetone ------------------------------- No Effect
Acetyl Chloride ------------------------------ No Effect
Acetyl Salicylic Acid ------------------------ Minor Effect
Acetylene (Ethyne) --------------------------- No Effect
Acrolein (Acrylaldehyde) --------------------- Minor Effect
Acrylonitrile -------------------------------- No Effect
Adipic Acid ---------------------------------- No Effect
Aero Lubriplate ------------------------------ No Effect
Aerosafe 2300 -------------------------------- No Effect
Aerosafe 2300W ------------------------------- No Effect
Copyright
scotto79   +1y
So Mat, did you have permission to reproduce that list?
TwistedPhil   +1y
Thank you for posting that list- it's good to know that I could use my fuel cell for beer instead!! Maybe now I'll build two!
