tacoma v8
tacoma v8
JRS KUSTOMS avatar
JRS KUSTOMS
i just want to see if anyone has put a small block chevy in a tacoma, and maybe give me some advice. I'm sure i can do it I'm just looking for the pros and cons of the swap.
bagged2dragg avatar
bagged2dragg
spicy avatar
spicy
it would be easier to do a ford 302 due to the front sump on the sbc i had to section the oil pan and the steering is all in the way but mine has all taco rack and pinion still ...you'll have to build a firwall and trans tunnel is huge the motor mounts are similar to a s1o swap and the headers im using are s10 headers.......an s10 drive shaft fits perfectly over a stock taco driveshaft so makes it easy to splice the 2.......my advice DONT DO IT
