Audio/Video \  protction light on amp
Audio/Video Q & A
views 337
replies 4
quinn625   +1y
when I turn my cd player up the protection mode light come on and goes off when I turn it down.
biguglywagon   +1y
What is your amp running(mids and highs or subs)? Does it play at low volume and shut off at high volume? If it is mids, disconnect one speaker at a time and check it, you might have a bad speaker. If it is subs, check the ohm load, and make sure the amp is stable at that load. Or it could be a bad sub.
quinn625   +1y
the amp have two door speakers on each side the ohm load is 2 ohm on each side, I unhook the door speaker and left the rca on the amp and turn cd player and the amp came on and I turn the cd player up and the protection light came on, when I turn it down the protection goes off,I wounder if it is the cd rca inputs
bbrownderville   +1y
Check your RCA Cables, and your Power and Ground Cables on the amp.
SONOMAONBAGSLAYNDUBS   +1y
more then likely its a ground issue i c it everyday
