77 chev SFBD ?
riddinlow99@charter.net's avatar
77 chev SFBD ?
riddinlow99's avatar
riddinlow99
I have a 77 chevy 3/4 ton that Im about to start a SFBD on wondering what arms and spindals are out there for such a vehicle
maz duh's avatar
maz duh
If you have the cash the Dropmember kit from Porterbilt Street Rods looks like a great kit. You can get arms from ART or Cando(i believe) or use your stock arms to save cash. You can also use a stock crossmember and Z the frame for the same effect if you're lookin to save some cash. Once you get the front crossmember so its even with the bottom of the frame rails these trucks don't need much to lay body. A shorter rail would do the trick for the rest of the drop you will need. I think most ppl are using 2x4x.188 for the undercab portion. You would be well advised to switch out your 3/4 ton suspension and rearend for 1/2 ton components though as it will make wheel shopping easier. Hope this helps, hit me up if you have anymore questions
s10
last post by baha +1y
