driveline ?s
kyllokustoms@yahoo.com's avatar
driveline ?s
jealousonezenvy's avatar
jealousonezenvy
im installin my 4 link. i got 2 long 2 short bars. i have a 2 piece drive shaft. Should i run it forward or reverse? What should the pinion angle be set at? in my profile is what im runnin for baGS ETC...
Tacon19s's avatar
Tacon19s
Edited: 3/18/2008 1:50:04 PM by Tacon19s
I would always if space permits run a 4-link forward(just me). As far as pinion angle, set the rear end down 4 degrees from the junction of the two shafts. I would run the longer bars as your lowers. How much shorter are the other bars?
jealousonezenvy
about 4inches there off a MPV van
Tacon19s's avatar
Tacon19s
hmmmm, I dont know how they are built but being factory parts they are probably pretty short arent they? I would invest in a 4-link.
jealousonezenvy
i will pretty soon i got a damn good job in nevada 6g a month
Kyrasis6's avatar
Kyrasis6
Yes, a 4-link should always be built with the axel trailing the links. Reverse 4-links suffer more shock from bumps and will constantly try to steer themselves.
91&93b2600i's avatar
91&93b2600i
If you want to keep the stock gas tank location, just make the two upper bars a wishbone. If you look at seths(twisted minis). He has a good three link with stock tank location.
