electric question
electric question
9T
93 TOYSSAN
yea i have a 93 hardbody and a shave my turn signal on my bumper and i wired my turn signals on to my corners but know i want to wire my corner and turn signal on my corner and was wondering if anyone has done this yet... or know wat i could use to do this..thanks
TwistedMinis's avatar
TwistedMinis
I'm having trouble understanding what you wrote. But what I gather is you want your running lights and blinker to work off the same light?
If so, what you need is a 3 into 2 adapter. Any trailer supply will carry them. It has 3 wires going into a plastic pod, and 2 coming out. They are about $10 each. This will cause your running lights to work like normal, but when you turn the blinker off the running light will click on and off. Then once you make a turn the running light goes back to normal.
9T
93 TOYSSAN
ok cause i tried using some conection of a ck truck and it didnt work or i guess i dint do right cause the blinker just sayed on and didnt even move... well thanks Seth I will try that
TwistedMinis
Could be wired wrong. First time I wired mine my blinkers worked like hazard lights.
97hrdbdy's avatar
97hrdbdy
seth- is that the name of it 3 into 2?
trying to find some myself
TwistedMinis
I don't actually know the technical term for it. Someone else might though. I just went to the local bearing/trailer supply house and explained what I was doing and they gave me two of those.
