solenoid problem?
solenoid problem?
Y
YeLowFuLLSiZe
i go the these things damn near every month. i dont show out in my truck 2 much so the compressor doesnt run a whole lot.i'm running a 165 psi pressure switch and its hooked up 2 a toggle switch. is there another way to do this or is this a pretty normal thing.
tooleyhc's avatar
tooleyhc
I don't understand your question...
Are you burning up the compressor? Do you have a relay or fuse inline of the switch?
chris03hd's avatar
chris03hd
Proof read before you hit the post button.
Clear up your question, and you will get helpful answers.
tooleyhc's avatar
tooleyhc
Reads like a drunken text message! HAHA
TwistedMinis's avatar
TwistedMinis
I don't see a problem or a question.
Y
YeLowFuLLSiZe
my bad, i do need 2 proof read lol i keep on burning up the solenoid.
tooleyhc's avatar
tooleyhc
What solenoid? Where? There's a lot of solenoids on a truck...
97hrdbdy's avatar
97hrdbdy
i think he means the solenoid for the compressor
are you using ones that are designed for 1005 duty?
i know in the psst, i have had friends that tried to use ford starter solenoids and they would crap out pretty quickly
Y
YeLowFuLLSiZe
i have the ford starter solenoid and it burns up pretty quick. the 1005 duty is that a type of solenoid? i'm still learning some things with bagged trucks
randallss10's avatar
randallss10
the ford solenoid is crap i had that problem get u a stinger 80amp relay it looks like a ford one but way better http://cgi.ebay.com/Stinger-80-Amp-Battery-Relay-Isolator-SR80-Marine_W0QQitemZ170121219196QQihZ007QQcategoryZ50552QQrdZ1QQssPageNameZWD1VQQ_trksidZp1638.m118.l1247QQcmdZViewItem
will fix problem $15 cant lose
