ok i know this has been asked serveral times but i tired searching the topic and couldnt find much about it. what im wondering what to remove after i installed the carb? i know i wont need ECU or o2 sensor. but is there anything else that i might have to keep? such as the EGR valve? any theres a couple sensors in intake will i need? vaccum lines are removed already im just wondering about electrical so i can get rid of the clutter. thanks
lucky_brew
talk to "Russ-D" on here. he's the Mazda guru
dfifty
you can pretty much get rid of everything all the egr smog crap. all the sensors i think the only sensor i left was the one for the temp guage and the oil pressure guage.
X
xMariox
ya i know russ-D knows alot about mazdas, thats why im hopin it would reply!
jdm customs
you can rip it all off, just keep the pcv valve and hose, keep the vaccum to the distributor, and run the alt. wire to the choke if its electric. and the big hose that goes to the brake booster. everything else can be axed. i just ripped my truck apart so i remember.
maz duh
If you get caught running around without all your emissions control equipment in place in ontario they will most likely pull your tags. Even if you have a crooked e test that says you passed you will most likely get your plates pulled. They are really clamping down on that shit around here over the last few years. I got pulled into an MTO saftey lane with my old Hardbody and it was all kinds of not fun. Just as a heads up to you if you weren't aware.
guiltybydesign
Im about to buy a b2200 and i was wanting to do the weber swap. What does this do to the mileage?
