Chevy/GMC Trucks \  72 C10 SWB QUESTIONS
views 153
replies 3
02ramon20s   +1y
OK WHEN I Z THE FRAM TO LAY THE TRUCK FLAT OUT ON 20'S & 22'S . WILL THIS ALLOW THE TRUCK TO LAY ROCKER OR WILL HAVE HAVE TO STOCK FLOOR THE CAB THE LAY COMPLETELY OUT? ALSO I DO KNOW THAT I WILL HAVE TO RAISE THE TRANS TUNNEL BUT WOULD I NEED TO NOTCH THE CAB AND BED FOR THE DRIVE SHAFT.
blazn   +1y
you will still be about 1" from laying pinch. You can lower you cab mounts and get what you need!
02ramon20s   +1y
will i need to get a drop spindle?
bagged69c10   +1y
Yes you will need spindles and you will have to cut the cab for a one piece driveshaft. Check out 67-72chevytrucks.com Those guys know everything about C-10s
