rides
market
More
Events
Gallery
Wiki
Store
Threads
Rides
Market
Events
Gallery
Wiki
Store
Browse
Mazda Trucks
\ motor help
motor help
Mazda Trucks
Make Specific
views 213
replies 8
following 5
Bayou Dragger
is there a rod or push rod for the manual fuel pump ar does the leaver ride on the cam?
Overkill
the fuel pump lever rides on the cam. If you remove it, watch for the spacer between the pump and head. I missed it when installing mine after the engine was rebuilt and the lever snapped off about 500km later, no fun whatsoever.
dragginmazda86
I know on the 86-93 2.0 and 2.2 in just rides on the cam.
Bayou Dragger
Have any of you heard of the cam wearing out ,preventing the lever to move enough for propper fuel pressure?
jdm customs
um no, what is your problem bayou?
Bayou Dragger
I have a b2200i have fire good compression and i cheked timeing but still wont run the fuel pressure is low.
maz duh
If you have a 2200i as stated above, it should have a high pressure eletric pump in the tank, not a mechanical on the side of the block.
Bayou Dragger
that was a mistake on the i,but isnt it a 2600i not a 2200i it def has a manual fuel pump
jdm customs
is the filter old and plugged? a carb 2.2 only has approx 3-4 psi fuel pressure. there is also a 2200i that was relased primarily in cali.
