double triangulated 4 links
lt1suv@msn.com's avatar
psicolow1's avatar
psicolow1
Edited: 3/28/2008 6:04:46 PM by psicolow1
max, getting ready to do my rear suspension and wondered if you had an opinion on a double triangulated type set up. just wondering how this would affect roll/instant center etc.of corse anyone else that has an opinion also please chime in.
maz duh's avatar
maz duh
psicolow1's avatar
psicolow1
thanks for the input, read it and it helped a lot. much apperciated.
BioMax's avatar
BioMax
Does that mean that all of your questions have been answered?
psicolow1's avatar
psicolow1
not really, it helped but didnt answer all. i can basically see how the instant center could still be calculated traditionally but with the weird roll center, would it be feasible for a street driver? seems to me like it would have 2 roll centers,but,wouldnt the actual roll center be a point somewhere between the two? am i way off thinking this?
BioMax's avatar
BioMax
The roll center that you are thinking is a single point is actually an axis Technically speaking it should be addressed as the relationship of the upper and lower bars to the rearend, but that is a whole lot tougher to explain that then just a simple point. Up until now, I have only described the roll center of the rearend as a single point, and it is, but it's the singlt point where the axle centerline crosses the roll axis. The upper bars have a roll-center and the lower bars have a roll-center, the line drawn between each of those points is the roll axis.
On a double triangulated 4-link, the roll axis will be at a faily severe angle and will generate either roll-oversteer or roll-understeer which isn't always bad, but needs to be kept in check.
