? on setting up 8 valves
kyllokustoms@yahoo.com's avatar
jealousonezenvy's avatar
jealousonezenvy
i got 8 valve setup . how do you set yours up? where do you run your air lines from the front of your truck to the back?
slammedxonair's avatar
slammedxonair
you could mount all of them together if you want like on the tank. or i usually do 4 on the tank or rear frame for the rear, and 4 on the front under the hood or on the frame for the front.
menace's avatar
menace
Thats how it needs to be plumbed.. You can mount the valves wherever you want, just make sure nothing is gonna rip them off, and route your lines away from exhaust heat, and tie them up out of the way
onebadkota's avatar
onebadkota
I mounted all mine on the tank...I think its easier to work on if there are problems....front left in one port, front right, back left, back right...etc..(if your running gauges just put some quick connect T's under the cab in the frame somewhere...then just run all air line through the frame to your tank
LowOrange88
I mounted 4 in the back for the rear bags, and the other 4 are up front behind the grille mounted on the radiator support. I ran one supply line to the front and tee'd it off to supply the 2 fill valves in the front, and I used a check valve on the supply line.
