Where can I get these...
dooredford@gmail.com's avatar
DooredFord's avatar
DooredFord
TAC Units so my LED's actually function and I can start driving at night, 80 bucks seems like a rip off and im not a member...
Wish I could find them locally but Streetbeat says they dont carry them...
http://www.fbirides.com/product.asp?idno=8862
CS
cheeks Sunset SD
I am a member but i wont use my membership biggest waste of money i have ever spent. try hi-tech
Severed701's avatar
Severed701
yeah..DO NOT waste your money on those..my buddy got some from a hot rod place somewhere for like 10 bucks..if you can hold out till tomorrow ill pm you with the info
Severed701's avatar
Severed701
nevermind i just got ahold of him...they are 5.99 from customclassic.com here is the link http://www.customclassic.com/products/lights/frenched.htm#pigtail
DooredFord's avatar
DooredFord
Edited: 3/31/2008 9:06:34 PM by DooredFord
Will that pigtail thing work from factory taillight wiring to the LED that just has black and red wire on the back of it???
I dont care about turn signals but i need brake and running lights.
bagtodrag's avatar
bagtodrag
AVS makes one that works for Ford wiring
DooredFord's avatar
DooredFord
what's their website cant find it
bagtodrag's avatar
bagtodrag
Edited: 3/31/2008 9:22:01 PM by bagtodrag
Here ya go Mike heres a direct link. These should do the trick.....http://avsontheweb.com/product.php?productid=399&cat=113&page=1
3yrididit's avatar
3yrididit
i actualy have a way to do this with a realy common item....i was playing at work....(gm dealer) and had a 3rd brake light off a tahoe that was 2 wire and wanted to see if i cound make it dim for park lamps and bright for turn and brake lamps and the first thing i tried worked realy well....its so simple...i figured it out by disabling drl lamps on a cop car.....heres how...you take a common relay found in any car. use just the coil side run the park lamp voltage through the coil on the relay..it acts like a resistor and dims the lamps....then you take the turn signal and brake lamp wire and bypass the relay to make the light brighter..it is that simple. u just need 2 relays...one per side and and some common eletrical connectors. thats my good deed for the day. kent tx
