Mazda Trucks \  v8 swap transmission questions
Mazda Trucks Make Specific
views 905
replies 12
following 9
mazdarado   +1y
What trans are you guys using when you do a v8 swap? Chevy and Ford both. Has anybody went with a 5 speed and what did you do about the clutch (hydraulic or cable)? I really want overdrive. My ideal setup would be a 5.0 and 5 speed.
maddawg   +1y
4L80E
Behind a 383 stroker.
gregsmazda   +1y
i got 302 with a modified AOD fits great(uses solid input shaft which removes lockup feature, can handle up to 400hp easy) i still have overdrive (.67 ratio in the AOD) but the converter will never lock up. . uses a TV cable that hooks to the carb for the kick down
mazdarado   +1y
Anybody else?
idrgbdy   +1y
Originally posted by maddawg
4L80EBehind a 383 stroker.
what kind of stand alone computer you got and how much that set you back? where you get it too? thanks.
maddawg   +1y
what kind of stand alone computer you got and how much that set you back? where you get it too? thanks.it' by a company called hgm.i can change the setting on the fly.i love that thing.i got it with the tranny when i had it built.i don't remember ho much the computer was alone .i paid 4500 bucks for the trans and the computer together.
bdydrppup   +1y
ive have a carb 305 with a modded turbo 350 and also had a tunedport efi 305 with a 700r. thinkin of swappin to a 5spd and using a wilwood underdash master cylinder
mazdarado   +1y
Is the 700r computer controlled?
bdroppeddak   +1y
you just need a lockup for them....
idrgbdy   +1y
the 700R4 is the same as the 4L60. and the same as the 4L60E, but not electronic. i think these are all the GM and Ford electronic trannys:
GM 4L80EGM4L85E GM 4L60EGM4L65E GM 4L60E transaxle (Corvette) Ford AODE Ford 4R70W / 4R75W Ford E40D Ford 4R100 ZF4HP-24
to use a carbed motor with electronic tranny, this is the kit maddawg is talkin bout. it's expensive, but i think i might use it:
http://www.compushift.com/products/compushift
