Front Track Width
Front Track Width
scotto79 avatar
scotto79
My brother is kicking around an idea and is looking for a vehicle that has a 58" front track width to start a full frame build for an SUV. Anyone know of any truck or old car frames that are roughly that size?The S10 is only 54", so that would be too small for it.
scotto79 avatar
scotto79
I found the Colorado has a 57.5" track, but then we would get stuck with 6 lug. Would it be harder to widen an S10 or Toyota front instead?
unusualfabrication avatar
unusualfabrication
Why not use the S-10 or Yota clip and make longer a-arms for it? That would work as long as you could get everything you needed to inside the frame rails.
Deranged731 avatar
Deranged731
I am with Chris. ^^^^^^^ Or you could widen the crossmember a little? But the longer control arms would be the best. IMO.
scotto79 avatar
scotto79
Good plan, I'm sure that would be more cost reasonable as well with just S10 parts. I would just be able to go an extra 1" and run a nice wide wheel in the front. Thanks for the input.
unusualfabrication
You'll also get some more lift as long as the balljoints allow the extra travel.
