toyota rearend in an isuzu spacecab??
tuknrail@yahoo.com's avatar
TuKnRaiL's avatar
TuKnRaiL
What year toyota rearend is best to use for this application?? Is thjere a rearend around 56" Wide??? Can anyone help me out???
bdydrppup's avatar
bdydrppup
what year space cab?akes a big diff. the 88 up isuzus are alot wider than 81-87. i have a 85 yota rear in my 86 space cab, tucks fine bagged but will rub and have to be narrowed for a bodydrop. if its newer bodystyle you will be fine. ive got another yota rear in da shop from a 94, ill measure it
bdydrppup's avatar
bdydrppup
by the way, the older the toyota the narrower the rear end
TuKnRaiL's avatar
TuKnRaiL
the spacecab is a 94. is that older toyota still 5 lug as well?? Yeah man kool!!! Measure it and let me know if you can!!! I got 2 places here to get a rearend from just trying to see which one I need!!!
bagdb2200
Axle width:
73-78 ~ 53"
79-83 ~ 55"
84-88 ~ 57"
89-95 ~ 58.5"
95-04 ~ 60"
Those are from Seth's sticky in the Toyota section.
fatboysS1O's avatar
fatboysS1O
Axle width:
73-78 ~ 53"79-83 ~ 55"84-88 ~ 57"89-95 ~ 58.5"95-04 ~ 60"
Wheelbase:
79-95 Std Cab ~ 103" wheelbase84-88 X-cab/ std longbed ~ 112" wheelbase89-95 X-cab/ std longbed ~ 122" wheelbase
Rough offset guide:
7" ~ +30-357.5" ~ +35-408" ~ +40-458.5" +45 and up.
thats Seth's sticky from the yota forum. i helped answer a isuzu question before the isuzu guru himself: Cobb!!!!
fatboysS1O's avatar
fatboysS1O
now that was just gay dropt!
bagdb2200
You were 2 minutes too slow! lol
bdydrppup's avatar
bdydrppup
well there you go, i measured that one but they beat me too it haha id go with the mid 80s and all 2wd yotas are 5x4.5 pattern
TuKnRaiL's avatar
TuKnRaiL
Alright well my next question is. We are planning on running centerline smoothies on the truck. On there web site it says that the 20x8.5 wheels comes with 5.4 " of back spacing and a 19mm offset. Will these rims work with the 55" toy rearend with the stock frame??? Thanks
Related Discussions in Isuzu
