front mounts for hydraulics
cutatbirth
i have a 1990 isuzu pup that im am doing hydraulics in im stuck on the front on how to make a mount and still be able to run a good amount of spring if anyone could post up pics of there setup or lead me in the right direction it would be very appericated thanks
HarryBalls's avatar
HarryBalls
Your probably best off using mini coils if your going to run springs....or honda coils etc.
cutatbirth
anybody else have any ideas i need to get this done and the mounts i made bent im stuck because of the tight clearance of the upper control arm
mista337's avatar
mista337
you could ditch the coils and just run accumulators to the front.
lobdyblazr
you could prolly use honda coils and get a good ride
Just build the mounts as high as you can..and keep the springs as long as possible.
Byrdman's avatar
Byrdman
talk to 4u8rs, tn jeff, hes the only person i know that is badass with hydros, i bug him about all my questions with hydros
cutatbirth
Thanks guys for the help i ended up going with mini coils and it worked out pretty good im not geting alot of hop out of it but its hitting bout 2 foot bottom of the wheel with only 1 pump to the front and four batterys
Related Discussions in Isuzu
