sandblaster or paint striper
tuckinlugs06 avatar
tuckinlugs06
whats the best way to get a truck bed down to bare metal without sanding it ....i have looked into the portable sandblasters but what do i use sand/glass/shells...what will only remove the paint primer and body filler
tuckinlugs06 avatar
tuckinlugs06
gravity or pressurized
tuckinlugs06 avatar
tuckinlugs06
Edited: 4/8/2008 11:50:24 PM by TuckingLugs05
anyone tryed this one ..i may get this one or one of the red standup 40 gallon ones not sure
http://cgi.ebay.com/Portable-Sandblaster-Sand-Blaster-Air-Compressor-Tool_W0QQitemZ260227935443QQihZ016QQcategoryZ43570QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
TwistedMinis avatar
TwistedMinis
I like aircraft stripper. Very cost effective and not as messy.
slammedcivicsi avatar
slammedcivicsi
I would personally just sand it....its going to be the cleanest way, and offer the best result.
I wouldnt sandblast anything myself. Ive done it too many times, and it just makes a mess. Same goes for chemical stripping, its a mess.
I would just get a big thick foam backing pad, and get an 8" 80 grit, and blast the paint off. Ive stripped hundreds of cars, and thats my favourite method.
tuckinlugs06 avatar
tuckinlugs06
will the stripper take off bodyfiller or just paint
dan48p avatar
dan48p
seems like the real old fillers don't like to come off real easy but the stuff thats been on for less than 5 years comes off with the stripper.
you usually gotta knock the last bit of filler off with some sort of abrasive no matter what though.
tuckinlugs06 avatar
tuckinlugs06
well i may not have to strip the bed if i find a new one that no one has molessted..but if i cant the i will have to try and save this one
TwistedMinis avatar
TwistedMinis
In my experience,t he chemical strippers soften the bodyfiller a lot. If its thin, it usually peels off in one piece. If its thick it comes off in layers.
slowram avatar
slowram
if u sandblast the bed, be careful that u dont warp the metal. warped a 58 impala hood bad back in the day, that was not fun to fix
