Ask A Pro \  need some help with a 2001 silverado wheel and airbag suspension problem
Ask A Pro Q & A
views 301
replies 6
following 7
bombir6   +1y
hi. i have a 2001 silverado that i bought 22 inch giovanna caracas wheel 22x9.5 offset is +30. now i decided to bag the truck and was wondering if these wheels with the +30 offset will tuck or not. or do i need a +40 offset.thanks in advance. also what will be the size of tires that will fit best so i can tuck with no issue.so far i have purchased the kp 4 link with cantevelier. firestone 2600 bags. front cups. 2 inch drop spindels. and am still working on the compressor setup and tanks.
dufur2003   +1y
Although I don't know the answer to your question I don't think that this is exactly a question for Max. He is more of a suspension and geometry guru.
thacru78   +1y
I would run a 265/35/22. That's what most people are running on them. As for the offset. If the rims are on the truck already just look down the side of the truck and see if they stick out. If they do then they wont work, if they don't then your golden
IMDORED   +1y
I RUN A 265/35/22 WITH A +50. I DON'T KNOW ABOUT A 30 TUCKIN THE REAR, MIGHT BE CLOSE. I DO KNOW THE FIREWALL NEEDS TO BE TUBBED AND THE BOOSTER IS AN ISSUE. THE COOLANT OVERFLOW AND FUSE BOX ALSO NEED SOME RE-ARRANGING.
GMracer   +1y
yes it will clear, you may be close or have to roll the fender lips but it will tuck
BioMax   +1y
Casey is right. I get this type of question all the time, but I really have no idea about specific vehicles. I'm more of a theory/problem solver. Sorry.
CCtuckinlexaniz   +1y
ya not to sure this question is for max, but no i dont think it will work. it will if u flare out the fender a lil, then u MIGHT be ok! i have 24x9.5 wit a 35+ off set and my tires are 255/30/24 and i still rub a lil bit. so i would just imagine wit the 30+ off set u would rub more!
