need more lift
begfomurrcy@yahoo.com's avatar
need more lift
suckafree's avatar
suckafree
just curious as to what bags everyone is running in the front of their mazdas? I am about 3/8'' from untucking my 18s up front and using conitech bags, truck is body dropped 2&3/4''. Trying to avoid cutting the front bag brackets out.
idrgbdy's avatar
idrgbdy
you got suicide door front cups? what psi you go up to?
idrgbdy's avatar
idrgbdy
damn, looks like you've had your share of mazdas. lol. no lift problems with those?
MazzyMatty's avatar
MazzyMatty
re-6's in mine
kaoss's avatar
kaoss
You might want to try unflipping your ball joints if they are flipped, and see if the truck still lays out. Re6's may give you the extra lift you need, since they don't balloon out as bad.
bagdb2200
The RE-6's clear my 18's on the front of my Mazda with the same amount of BD as your's.
suckafree's avatar
suckafree
no sd.com cups, previous owner did homemade tortion brackets. no flipped ball joints. I'll try the re6's.
dssur's avatar
dssur
make sure the bag is squishing all the way. If it takes 50-60 psi before the truck even moves, you are losing lift.
also, if you have drop spindles, make sure the upper arm has been trimmed at the outmost edge by the balljoint. The arm will hit the spindle if it isnt and keep you for getting more height.
kaoss's avatar
kaoss
^^^ you can probably run 3/8" worth of spacer in there to get the extra lift.
suckafree's avatar
suckafree
bags are completely compressed layed out no room for spacers. no spindles either...lays on stock components.
