Hydro boost on a gmc 4.3
los51881@juno.com's avatar
treylos's avatar
treylos
Will a hydro boost setup fit a 4.3 v-6 its in a 2003 sierra?? if so what years will fit??
dubDyme
just did one on my 01 s10 with 4.3, one from late 80s 2500, newer 2500s, astro vans...mine was from a 95 astro van, the difference was the location of the mounting bracket in relation to the booster. the 95 astro will be straight, whereas the 2500s will end up raising your booster a bit. i can also give you part numbers to help with getting your lines fixed up.
davaflav
i have a 05 silvy 4.3 5sp and swapped in a hydro boost setup froma 02 1 ton sierra
davaflav
youll need
booster
master
power steering pump
brake pedal
and all the lines with it
20runner's avatar
20runner
dubDyme,, I am interested in doing the hydraboost from an Astro van myself, also on a 4.3, 2000 Blazer. How mcuh did it run you in parts? Did you get a used unit from junk yard or a new one? Does the stock master bolt to the Astro booster? How do the brakes feel? Thanks in advance..
