gas filler neck material help help help please1
stopndrop
i had to move my gas tank on my bravadaforward from stock location. i want the filler neck to go back in the stock mount for the gas door. my question is wat can i use to make and extenttion. it has to be flexable cause i have to bend it around the notch and frame.
blackice's avatar
blackice
I ended up welding together pre bent exhasut tubing for mine. I looked at using all rubber hose, but 3 feet of 2" fuel safe rubber hose was going to be rediculously expensive
CLNSHVNnDRAGGN's avatar
CLNSHVNnDRAGGN
When I redid the filler neck on my Sentra I went to a hose supply place and got the same rubber hose that gas stations use on the pumps. I think it was about $5 a foot.
