2 viair 450s
suthrn98@aol.com's avatar
2 viair 450s
low mazda's avatar
low mazda
ok it's in my honda, but i know it'll get answered here. what size fuse should I be running. I blew a 30 amp when we hooked it up, and i just blew a 40 amp on the way to work this morning, and had to ride home with no air. that sucked balls. each compressor is rated for only 14 amps, so i thought a 30 or 40 would do the trick.. what gives?? what size do I need to run?
Jcfreeman0's avatar
Jcfreeman0
i thought viair 450s were 23 amps max. i'd get a 50 amp.
low mazda's avatar
low mazda
ok, well I went and bought a 50 amp, and it blew. what's the biggest that would still be safe, and/or, what could be the problem why they keep blowing?
TwistedMinis's avatar
TwistedMinis
If you keep blowing amps something might be wrong. I usually run 40 amp relays and never have issues.
IMLOWER's avatar
IMLOWER
i ususally use the 30 amp realays and with 2 comps a 60 amp fuse never had a problem with tha tset up. what gauge is your wireing you might need to upgrade teh wire size
idrgbdy's avatar
idrgbdy
ya i got a 50 amp on (2) 480s. no probs. make sure wire size is right.
slammedxonair's avatar
slammedxonair
are you just running an inline 30 amp fuse or relay? because your post does say fuse and that could be the problem.
low mazda's avatar
low mazda
i have a seperate relay (30 amp) for each compressor. 8 guage wire into each relay..
low mazda's avatar
low mazda
to think of it, it would have to be a wire problem. after i canned the car, it ran fine for a few days, then yesterday it started screwing up. I guess I'll have to check the wiring in the morning.
