Mazda Trucks \  bag question??
bag question??
Mazda Trucks Make Specific
views 198
replies 2
xMariox   +1y
ok well right now im running firestone bags but lookin to put in slam Re6 bags on, i noticed the bags are rated for 200psi, will i loose any lift if im only running a 150psi set up? cause im also got a 3 inch body drop so i need as much lift as i can. if anyone would know id appreciate it.
laydsuzu   +1y
depends on the weight it takes to lift and clear the tires. mine is bd and i didnt lose any lift really in the back, just a little bit in the front, almost have to air it up all the way to clear the tires, but i still have stock arms.
low_blazer   +1y
The 200 psi is a max pressure rating fpr the bag...not the system requirement. You'll be fine, and get more than enough lift out of the front with those bags.
