Page 1 of 3
Mini Truckin General \  best place to get a fuel cell??
views 693
replies 26
following 17
lost cause   +1y
I need one for my 96 tacoma,....any one know a good place to get one for a decent price
lost cause   +1y
any one know if this one will work?
http://cgi.ebay.com/ebaymotors/10-GAL-RCI-FUEL-CELL-TANK-ALUMINUM-PRO-NHRA-W-SENDER_W0QQitemZ130215454714QQcmdZViewItem
it says it has a gm sending unit????I don't know shit about this stuff any help would be appritiated
TwistedMinis   +1y
RCI cells are not that impressive. I've installed 3 so far, and none of them where even remotely square. And their mounting tabs are a joke. They need to be fully supported from the bottom with a large rubber strip, or the tabs will pull off. And its a GM style sending unit, so your fuel gauge will probably work backwards. I just hooked the one up in the 720, and its dead empty, and with the ignition on it goes past the full line on the gauge.
truck action   +1y
Have one made,aluminum or stainless,use the senders & flanges from your stock tank,or get a donner tank!
lost cause   +1y
Thanks seth,....can you recomend one for my tacoma?....or a place to get one?
Thank lot for the help man
lost cause   +1y
I wounder how expencive and time consuming that would be....I can't weld aluminum or stainless so that might not be the best idea,...
I'd like to just buy one and install it
Thanks for the advice though
ALL 20S   +1y
I have a summit made one, works perfect, decent price too, I think it ran $150
lost cause   +1y
^^^^Thanks all 20's......where did you get it? got the web site or a number?
Thanks lot guys
2LOW4U   +1y
summitracing.com or jegs.com have tons of them
unusualfabrication   +1y
Having one made might not be as expensive as you think. I am working on a custom cell now that uses the stock sending unit and I only charged the guy $250 for it. Its all aluminum, bead rolled, stock sending unit and pump, holds app. 20 gallons, and filler neck. He would have spent close to that on one from Summit, after shipping, and its custom fit to his custom back half.
