Mazda Trucks \  layin with 20s?
layin with 20s?
Mazda Trucks Make Specific
views 383
replies 7
following 6
jealousonezenvy   +1y
i bought some akuz 20s with 6 inch of backspaceing, i have flipped upper and lower control arms and drop spindles. question is will they tuck and do i have to move or relocate anything? my fenders are all cut out also
unusualfabrication   +1y
If your ever interested in tubular control arms for it I make them, lay on 20's, and eliminate the factory strut rod. Sorry i'm not sure on the back spacing. Just a shameless plug for my arms, lol.
slammedstroller   +1y
how wide?
what size tire?
I have 20x7.5 with 30 series rubber... stock arms, drop spindles no flipped anything it lays.. but ball joints max out as soon as the frame hits the pavement
slammedstroller   +1y
oh and you will probably have to move your clutch master cylinder or rotate it counter clockwise a bit and you'll need to tub the firewall if your bodydroped
jealousonezenvy   +1y
245 r 35. 8.5 inches wide
slammedstroller   +1y
YOU WILL NOT BE ABLE TO LAY THOSE WITHOUT CUSTOM ARMS AS FAR AS I KNOW.... I WOULD LOOK INTO GETTING 30 SERIES RUBBER... THAT SHOULD SET YOU ON THE GROUND.. THE MAX DIAMETER I CAN LAY OUT ON IS 24 1/2" HERE IS THE WEBSITE I USE TO GET DIMENSIONS http://www.miata.net/garage/tirecalc.html PLEASE NOTE THAT THE DEFAULT "STOCK TIRE SIZE" IS FOR A MIATA NOT A B SERIES
HOPE THIS HELPS
jealousonezenvy   +1y
tires are 225 r35 20 will they tuck?
mazdawgon20   +1y
i have 235/30/20 with 20x8.5 and i am running unusual fab arms. i am also got a 3.5 bodydrop
