strongest interior spray-glue ?
25 following
violentdemise@msn.com's avatar
Slappy Mc Nasty's avatar
Slappy Mc Nasty
ive done many interiors and have used various adhesives in the past, usually walmarts "interior trim adhesive" (about $10 in a black can) in the auto section but im curious as to what others in different regions of the country. im thinking of using a soft, stretchy fabric so its not gonna be too heavy.thanks in advance to anyone who chimes in...............
charlesskelter's avatar
charlesskelter
I use Permatex Heavy Duty Headliner& Carpet Adhesive. I got it from Autozone. Holds like a f'n champ. I did my headliner out of denim so it's not the lightest, and it's holding strong. I did my ex's out of suede and her a, b, and c-pillars in silk with Super 77 and it's already sagging. So I'll have to get all new material and do it all over again.
CLNSHVNnDRAGGN's avatar
CLNSHVNnDRAGGN
DAP Weldwood Contact Adhesive
balistiks10
i used 3M super 77 but was not happy with the results
jealousonezenvy's avatar
jealousonezenvy
i use heavy duty spray adhesive that i got from my insulation job white can red lettering
TOYBOY89's avatar
TOYBOY89
Use Landau top adhesive and spray it with a cheap suction paint spray gun. This is way cheaper than using spray cans, a 1 gallon can is about $30 and would do probably 3 or 4 complete interiors. Play around with the spray pattern because you dont want to heavy globs, they will bleed through the material. Good Luck
beyondstockyota
I've seen glue systems where the glue was atually pressurized in a tank much like a propane tank. This allowed for portability and easy use. But I never figured out what the hell it was...
wickedinsides's avatar
wickedinsides
dap weldwood in the 5 gallon bucket
pearldrop's avatar
pearldrop
DAP Weldwood Contact Adhesive is the only way to go.
EKSESSIV CONTROL's avatar
EKSESSIV CONTROL
where do you get it
