who sells front torsion brackets for a 1996 toyota tacoma
switchhittin96
Edited: 4/25/2008 11:47:46 PM by Leanin
actually im not to sure if there called torsion brackets but i am talking about the brackets that are level with the frame with a slight upward tilt to them?
switchhittin96
switchhittin96
Edited: 4/26/2008 12:35:57 AM by Leanin
Edited: 4/26/2008 12:35:25 AM by Leanin
Edited: 4/26/2008 12:35:01 AM by Leanin
this is more of what im talking about: http://smspecialties.net/index.php?option=com_expose&Itemid=29
that is just a reg ole torsion bar setup in the first pic. second picture goes to a gallery.
that little piece that angles the circle plate should only be used when you have drop arms installed. if you're running stock lowers, it gives the bag a really nasty angle when you use that little piece under the circle plate.
switchhittin96
ahh i see, any idea where to order these?
suiciedoors.com, gravity-werx.com, fmkustoms.com, fbimini.com, whynotfab.com, literally anyone who sells air ride parts has em.
mindlissmetalfab's avatar
mindlissmetalfab
I have torsion kits. $65 shipped. The gussets are a little nicer than most kits out there. I figure if you are paying for a laser cut piece, it might as well be laser cut for a reason.
