good welder for beginner
justin.bonds@gmail.com's avatar
bundston's avatar
bundston
whats a good welder for someone that hasnt done much more then tac in some door handle fillers?
standardbyker88's avatar
standardbyker88
i would say a miller or lincoln 110 welder. wirefeed style, with the option of using sheilding gas. one with adjustable wire speed and different voltage settings...either a rotary switch or a knob.
also, having the option of different wire size is good. .20 - .35 is about the range youd need depending on the application. also, get a good welding mask. not the hand held kind, the style that you put on your noggin.
CLNSHVNnDRAGGN's avatar
CLNSHVNnDRAGGN
I would say go with a 220 right off the bat. I tried learning with a 110 and it had me hating welding. When I got my 220 I picked it up and started laying beads like I had been welding for years and it wasn't even a high end welder (Lincoln 175 w/gas).
crewcabondubs's avatar
crewcabondubs
http://www.millerwelds.com/products/mig/millermatic_180_autoset/
this is a nice machine. its good for beginners cause you dont have to worry about if your setting the wire speed and voltage at the wrong level.
bundston's avatar
bundston
thanks for the info
minitrucker04
i got a lincoln 140, and it works bard ass it a 110 unit
Severed701's avatar
Severed701
Originally posted by CLNSHVNnDRAGGN
I would say go with a 220 right off the bat. I tried learning with a 110 and it had me hating welding. When I got my 220 I picked it up and started laying beads like I had been welding for years and it wasn't even a high end welder (Lincoln 175 w/gas).then i would say you were not using the right machine for the right job..it really depends on what your doing with it. i LOVE my 110 lincoln for doing sheetmetal and light stuff..but when i need to burn the fuck outta some metal i use my 220...but i wouldnt use either of them for everything..they both have there uses respectively
standardbyker88
exactly. and for a beginner, i would suggest warping some sheetmetal before you chicken poo a frame notch.
bundston's avatar
bundston
wow its like you read my mind
Related Discussions in Tools
