upper balljoint question
hells gate avatar
hells gate
Ok I know the moog balljoints supposedly have more travel than factory, but what if they don't?
The factory and the moog side by side on the counter seem to have the same travel. And my factory upper bind.
bk2life avatar
bk2life
pie cut your UPA's and use the stock stuff
hells gate avatar
hells gate
Upper arms are tubular not stamped, not sure how they're made, was told they're cast but not sure. I should have mentioned they're on a 92.
crewcab avatar
crewcab
I had the same problem so i heated up the arms by the balljoint area and bent them till they dont bind anymore
hells gate avatar
hells gate
I was actually getting ready to heat mine till I paid attention to how much extra material is on that balljoint. A lil selective grinding with a small deburring tool did the trick. Pumped a crapload of grease through em when done to make sure I had no shavings.
