Mini Truckin General \  building my own control arms
views 288
replies 12
following 11
drgnrockr   +1y
is it easy to build a s-10 control arm or should i buy them.
jdauer02   +1y
if you can cut, weld and bend DOM I would think you could make some.. If not buy them from Barely Legal fabrication.
impulse   +1y
i'd just buy them from suicidedoors.com
I personally wouldn't waste my time making something that is readily available, and works like it should, unless you wanted to be super cool and have your own one of a kind arms.
guiltybydesign   +1y
^X2
Unless your going for a set that are one of a kind its better to just buy them. I made my uppers myself but theyre nothing like anyone elses arms.
nissandoordragger   +1y
i made my own but thats cuz i felt it was retarded to spen 700 bucks for control arms when i can make them for less than a hundred
drgnrockr   +1y
well in that case i will build then does anyone know if theres any speical measurements i need or bends you know anything like that
Master Fabber   +1y
Do you have suspension fabrication experience? Im not trying to be a jerk, but if you dont know what bends are going to be needed or special measurements or cannot figure it out, are you sure you can build them? I mean someone cant tell you exactly what degrees to make everything or dimensions of everything over the internet.Pretty important piece that needs to be built strong and safe. JR
drgnrockr   +1y
yeah i have suspension fab experience i just have never built control arms before and i dont want some one to tell me i just want an idea of what to go by cause i got my stick specs already.
Lunchb0x23   +1y
i agree with jayme, if you can cut weld and bend tubing, go for it, you'll save a lot of money and its badass to be able to say you fabbed it yourself... just make sure you measure 10 times and cut once
addicted4life   +1y
make a jig with all the mounting points secured(i.e. ball joint,cross shaft)
