LED wiring...
cru_78@yahoo.com's avatar
LED wiring...
thacru78's avatar
thacru78
Hopefully this hasn't been asked....I didn't see it when I searched.
Ok. I'm wiring up some LED's. They have 2-wires coming off of them. Then a little pig tail and the power wire splits. One goes to the brakes/turn signal, one to taillight. The problem I am having is, When you hit the brakes, the brake light covers up the turn signal. So if the brake is pressed, then you can't see the signal flashing. Anybody got any advise on how to wire them were they work. Thanks for the help yall.
NIGHTMARE73's avatar
NIGHTMARE73
THATS NORMAL !! AS LONG AS THERE BRIGHTER THEN YOUR RUNNING LIGHTS ,, MOST OLDER CARS AND TRUCKS WERE THE SAME WAY ! ,, TRAILER LIGHT ALSO !! YOUR RUNNING LIGHTS SOULD BE DIM , THEN WHEN YOU HIT THE BLINKER OR BRAKES THEY GET BRIGHTER !
2LOW4U's avatar
2LOW4U
Check out avsontheweb.com
They have a couple different modules for the LED's. I think that is what your gonna need.
onebrokeminitrucker's avatar
onebrokeminitrucker
they make a signal splitter for trailers but most factory lights work as you decribe
