cylinder head plug?
shagee2000@yahoo.com's avatar
cylinder head plug?
shagee2001's avatar
shagee2001
How do you change the big plug on back of the head on a b2200? It's like a freeze plug but when it goes you loose lots of oil. Any ideas on fixing it besides taking the head off?
mooneyes1's avatar
mooneyes1
its just plastic so you can just push it in by hand and its held in place by the engine hook
shagee2001's avatar
shagee2001
So you just remove the old one clean up the area and pop a new one back in? Where can i buy this part besides the dealership? What is the proper name for this part? Originally posted by mooneyes1
shagee2001's avatar
shagee2001
Anybody else? Also what would be the best sealant to put on it... i need something that sets up fast and will stay.
Kyrasis6's avatar
Kyrasis6
It is the rear cam seal, can buy it at any auto parts store for about $4 The engine hook has nothing to do with holding it in, if it is not in correctly the hook will not save you. It is not likely you'll get it all the way in by just using you're hand.
The seal is actually held in by crush between the rear rocker arm cap and the cylinder head. The best way to put it in is to remove you're rocker arms install the seal then reinstall them.
Last time I did one I was able to get away with just removing the valve cover and loosening all the caps, then I pushed the seal part of the way in by hand. Once I had it partially started I placed a piece of flat steel over it and used a prybar against the firewall to push it the rest of the way in. Then I just retorqued all the rocker arm caps in sequence and reinstalled the cam cover. Took maybe 15-20 minutes. The seal is actually a metal cup which is coated with a hard rubber, it doesn't need any sealant but if you still want to use some any of the usual RTVs will work just fine.
