95 S-10 Project. Front Grille.
M_Baldwin
Hello everyone. Been doing research, on the last part now, getting information from others to assure my gatherings.
My 95 S-10 has the front grille and light set up of a normal 1995 S-10. Such as this one. http://i102.photobucket.com/albums/m85/vorsek/1997chevrolets101930-E.jpg
And, I am wanting to change the front grille and light set-up to a newer, 98+ year model, such as this one.http://i102.photobucket.com/albums/m85/vorsek/2001chevrolets-1020194551-E.jpg
I want to give it that, better look, its all part of my master plan for the S-10, and it seems to be a cheap, and quick part of it, but I need to make sure before I continue.
So, is it really as simple as buying a new grille and new lights, and popping them on? With minor wire-work involved, or Am I going to have to move the radiator, fan, or anything else?
The body style is the same, so technically, a yr 98 grille will fit on a yr 95 body style front end. But what about the junk just behind it? Will those pose a problem?
Please post any answers, and thank you in advance.
stickboy's avatar
stickboy
i think the core support, is different, the light pocket behind the lights would be different. but thats nothing a cut off wheel and a little fab. work cant handle, it might be easier on you to just get a diff core support when you do the swap. i have a 99' s-10 and a couple square body s-10s. but i sure the 95 and 98 are different cores.
waynehammer's avatar
waynehammer
fbi sells a conversion for a pretty good price
balistiks10
yea the 94-97 core support and the 98-03 are 2 different ones so u will need to change the support to update the grile
lucky_brew's avatar
lucky_brew
i just wanted to chime in and say i have no idea what will/wont fit. i just wanted to give m_baldwin props for actually being very descriptive when asking for help! good job! often times the question is more confusing than the various answers!
M_Baldwin
Does this guide entail what is needed to replace the front end core support?Front End SupportI do not know if he put a new grile on it, like I am wanting to do. But... is that what i need to do?
And thank you for the compliment LUCKY
