Page 1 of 3
General Discussion \  Need Pics of Front End Setups Heeellpp!
General Discussion
views 4390
replies 25
following 8
rick ross   +1y
Sappnin. I just got a 01 bagged and bodied dually. I have some front end issues!! The death wobble is horrible unless I am right on the sweet spot. Problem is the sweet spot is kinda low. Turning radius is non existant!! Post some pics of yours. I want to to see what shock placements work and what doesnt. I will post pics as soon as I figure all that out. Thanks for the help.
big bear   +1y
check your ball joints, tires, wheel bearings, carrier bearing,u joints, u get the point man. id check over all that stuff. those are some of the top suspects in death wobble. keep us posted.
comegetsome   +1y
you cant post a thread about a bodied dually and not put up pics.....
rick ross   +1y
^^ hahahahaha. I know. I love truck porn too. I have pics on my phone but dont know how to post them.Somebody shoot me a cell # and I will send them to you. I have been fliping thru my 700 plus lbs of magazines and most setups have the shocks behind the wheel. Mine are toward the front. I am just trying to find out what works best. What kinda shocks are everyone running?
rick ross   +1y
Soooo.... nobody wants to show of thier setup, huh?
bk2life   +1y
if you have shocks or not, you shouldnt have death wobble.
i have no front shocks, drive either 10 inches up or 1 inch off the ground and no wobble.
get your front end checked, and an alignment.
rick ross   +1y
Oh I know I have other problems. I get it. I just want see some set ups so when I get all my problems solved I can redo the shock mounts ,set it down off the jackstands and be BUTTER. It is cold here and I am trying to get this frontend straightened out before the snow comes.
bk2life   +1y
if your front end pieces are in good working condition, it should be parkay, there is really nothing to see on front end set ups. unless you mean shock mounting, and that is pretty much where ever a shock can fit without rubbing the wheel.
rick ross   +1y
Yeah the wheels rub on mine right about the same time the upper arms rub the inside of the wheel. I have lots of problems. Luckily the truck has a ass of work already done to it so its just a matter of picking a place to start.
rick ross   +1y
Aaarghhh! 1st snow today. Just a trickle to remind us that the real stuff is on the way!
