how tall are 18's?
how tall are 18's?
dfifty
i wana set my truck up to lay on 18's probably a 45 sereise tire. how tall would that be?
scotto79
http://www.miata.net/garage/tirecalc.html
it still depends on the tire width as well
SS
street sweepin cavi
yeah its all in the tire width... do you have discount tire in your area if so the have a metric converter that can help you get the exact width, side wall height and overall height.
lucky_brew's avatar
lucky_brew
all depends on what size 18s...
and also, like they mentioned above - it all depends on tire width.
example:
215/40/18 is 215mm wide and the side wall is 40% of the 215mm width.
so
225/40/18 would be taller since 40% of 225 is greater than 40% of 215.
but if you are mocking up the ride with some scrap tires then get a tire that is the same height as the 18" tire you are wanting to run.
hope that was more help than confusion.
