Ford Trucks \  Problems with my Signal Lights
Ford Trucks Make Specific
views 188
replies 7
following 6
dacustoms   +1y
I have a problem with my signal lights. I turn the left signal on and my left and right signals flash including my dashboard lights. I turn on the right signal on and only the right signal lights blink like they are supposed to. Do you all have any Idea what it could be?
OldSkool720   +1y
when u turn on your left blinker does both your tail lights go on, or just on your dash
bobogolfcart   +1y
poss a faulty or not connected "HAZARD" light switch
tcsxtremeison22s   +1y
or brake light switch....
dacustoms   +1y
When I turn the left signal both sides start blinking and my dash lights do too. Thanks for the info.
slmmdd97   +1y
check the turn signal cam also could be faulty they do go bad the truck i drive for work. had to get it replaced cause it was blowing the main fuse to make the truck drive it was weird
3yrididit   +1y
its a ground problem, feeding back through the brake lamp cir to the ipc....i do eletrical work on cars for a living and see missing grounds in light circuits do some realy weird things. check your light grounds and check the sockets for opens...
dacustoms   +1y
Thank you all very much. Ill try all of them and see what will work.
