Ford Trucks \  Bagging an 04 F150
Bagging an 04 F150
Ford Trucks Make Specific
views 127
replies 0
following 1
GCash   +1y
Im looking into bagging an 04 F150 and lay it out on 24's with a 305/35 tire. i've been researching for a couple hours and have some unanswerd questions. 1) can you layout with stock arms and a drop spindle, i've read the fliping the balljoints, but then read the spindle is all you need
2)the brake booster, some clear some dont, some run explorer ones, some run the mustang ones, whats the best route to go?
3) Do you have to notch the frame for the tie rod ends
4) Do i have to tub the firewall just to lay frame?
5) Do RE7's fit ok in the front
6) In the back, does the gas tank have to be raised up or anything?
7) Does the rear axel have to be shorten and is there room to run a triangulated 4-link with the stock gas tank?
