General Discussion \  3/4 8 lug rotors
3/4 8 lug rotors
General Discussion
views 1668
replies 11
following 5
2000lowrider   +1y
I have a 2000 crew cab dually and want to tuck the wheels a inch or so more.Its a 5-7 drop with 16 inch Alcoas.Is there a specific rotor needed or just any 88 thru 98 3/4 ton 8 lug rotor assembly.Same on factory Hd wheel spacers any specific year I have read on here that it works just looking for a tad more info...... Thanks
luv2xclr8   +1y
Subscribed cause I'm curious
big bear   +1y
hmm.. havent seen someone do this on a static. very interested as well.
2000lowrider   +1y
Shouldnt matter how its lowered just want to pull the wheels in board a inch or so to get the wheels away from the lip. The truck is a 2000 with 7000 original miles it was purchased from the original owner who stored it . It had 4700 miles on it when I bought it this year. It still had plastic on the rear floors and the fuses where taken out of the windows so they couldnt be operated while stored.Still smells new inside......
circuitguy   +1y
Did you roll the front fenders yet? This helps a bunch.
2000lowrider   +1y
Yes i did roll the fender lip with a tool made for that purpose .Thanks for your response....
circuitguy   +1y
Other options are to add the 4x4 factory flare so you can then cut the inner lip off of the fender, change the tire size or in some cases have the front tires shaved slightly to stop the rubbing. Just some ideas for you. I have the same problem with mine, I am looking for some different tires to help this problem.
comegetsome   +1y
why not just shorten your stock control arms 1 inch....I had to do this on my truck to get the lugs tucked...pretty common solution when bagging one will work static dropped too
2000lowrider   +1y
I have thought about a shorter arm or shortening the stock arms. I just figred the 3/4 rotor nd the GM heavy duty adapter would be quick and easy.I switched from a 235 60 series to a standard low profile dually tire with only 6 inches of tread and going striaght the tires will not rub . In a hard bump situation the may hit the fender well .When I do the rotors or a arms I will install a taller bump stop...I will search the forum for a arm mods....
circuitguy   +1y
Do you shorten the lower and upper arms together?
