General Discussion \  Dodge Dually
Dodge Dually
General Discussion
views 1530
replies 6
severedtiesdually   +1y
Ok so I know all about doing the chevys but the ram is a new ball game. Its an 06 with the cummins. What all needs to be done to the front to get it down on 22's and does anyone know about getting all 4 22's in the reat without wider fenders? I really dont wanna make it any wider than it is if i can help it. Any pics or info would be great. Thanks.
big bear   +1y
i dont know the specifics but normally you have a few options. widen fenders.....narrow rearend.... sometimes you have to do both. and on a chevy, you can run c
dat dood   +1y
Best bet is just narrow the rear. Its a full floating AAM axle and unlike the GM's AAM, the axle shafts are the same diameter from spline to hub. Cut the tubes, weld em back in, cut the shafts and have em resplined.
ratmosphere   +1y
We narrowed mine rearendas well.... and cut down the axles and had Moser respline them...however I have stock inner wheels....if you narrow...watch for the caliper for rear brakes and them touching the frame...we had to narrow the frame i think 1.5" per side starting right behind the fuel tank so they wouldnt touch...Any other info....lemme know...i'll try to help.
ratmosphere   +1y
Do you still tow with yours? I have a 50' 3 car to drag around.... I just dont want to have any issues.
ratmosphere   +1y
No I dont do any towing, but if I did it would handle it fine.....
