Air Ride Suspensions \  Rear setup for when ya want to go fast??
Air Ride Suspensions Q & A
views 168
replies 7
following 6
PS099430   +1y
Alright i know if you want to bag a truck you are really sacrificing traction for off the line ( in my head atleastt ) but when it comes down to it is there a setup that will give you more traction then another or do you just need to pick goes fast or going low?
Low_Smooth_Cool   +1y
what kind of vehicle?
twistofcain   +1y
a proper setup will allow u to launch straight and hard ..i set up drag cars all the time and i set up a bagged truck along the same lines
PS099430   +1y
68 chevy C10, i was just wondering cause there is a guy where im from that has a 454 ss truck with a supercharger and nitrous yeah his crazy but i saw it run before and after it was a bagged and there was a big difference for his traction.
twistofcain   +1y
the kinda shocks u use can have alot to do with the traction
bodydropped85   +1y
a properly setup 4 link will get good traction, regardless of spring. an air spring just is adjustble rate spring.
PS099430   +1y
alright than what type of shocks would be good to use? sorry for all the questions just want to do it right the first time
TwistedMinis   +1y
Call Steve at RCD Classics and tell him what you are trying to do. He will be able to help you with that more than anyone here.
Also look up anti-squat and how it effects your suspension, as well as how to build it into your suspension. There is a lot to explain, so its better to read up in a few different places. Chassis Engineering by Herb Adams has a good chapter on it. It talks about how drag cars use anti-squat to plant the tires on the ground more efficiently, and it also talks about being too greedy with anti-squat and the effects of that.
