Body work and Paint \  Metal finishing/grinding.
Body work and Paint Q & A
views 200
replies 5
following 6
impulse   +1y
What are you guys using to grind/smooth out welds in tight corners and stuff.... obviously a regular grinder isn't really going to get in there.
91&93b2600i   +1y
3" grinder and 3" angle grinder with one of those 3m or roloc green grinding disks
corey0814   +1y
depends on how tight of a corner...but a carbide bit on a die grinder or right angle die grinder
can't find the type i use, but they're real similar
or rat tail files, or hell, even a dremel
McClarys   +1y
depends ... cut off wheel is always good to cut most of it down ... even put a cut off wheel on an right angle air grinder..... then use a flap disk to finish it....
even those burr carbine that mention above is good.... save yourself some time and dont buy the cheaps one either.....
corey0814   +1y
definately don't go with the cheap ones. i had a set & i couldn't tell if the bit was grinding the weld or if the weld was grinding down the bit...
retrodrag   +1y
I used a cylindrical file for the 90 degree joints which I couldnt get the flap disk in. One of those carbide bits would work great though!
