shock advice
shock advice
str868
Need advice on drop shocks for my 1998 c3500. I didnt do the drop so I am not sure how much it has been lowered. It does have a djm flip kit installed and drop spidles in the front. The back shocks are 13.75-14 inches collapsed unfortunatley this leaves about a inch of travel. If anybody can recommend a good set of shocks I would appreciate it.
muskratt2's avatar
muskratt2
I went with the DJM's because that's the suspension kit I have.
I don't like mixing & matching stuff. I like them!
str868
Thanks for the advice. Did you use drop spindles in the front and if so did you you use 2"drop springs or stockers?
muskratt2's avatar
muskratt2
My truck is a Ford. I used drop beams!
