Mazda Trucks \  wiring ?s asap
wiring ?s asap
Mazda Trucks Make Specific
views 371
replies 6
following 6
jealousonezenvy   +1y
What wire to the ignition is your cd payer wired to? color? also what wire do i run my digital gauges to on the ignition? How does everyone have there pressure switch wired? i know one wire goes to the 12v and the other goes to the ignition but what wire do i connect it to? pics would be perfect also
karathos   +1y
try Bulldogsecurity.com. You can get your wiring diagram for you vehicle on there. It wont have stereo wiring, but it will have your ignition wiring, so you can always tap it there.
jealousonezenvy   +1y
what wire of your ignition is your pressure switch wired to? what about your digital gauges?
corey0814   +1y
i don't know the color, but just take a multi-meter or test light & just find any old ignition wire. doesn't really matter if it's for the radio, cigarette lighter, anything, as long as it's only hot when the key is on. that goes for your cd player, digi gauges & your pressure switch too...
kaoss   +1y
If you don't know how to wire the pressure switch and relay check Air Zeniths web site.
dssur   +1y
I dont remember the color of the wire off the top of my head, but I am replying to tell you there isnt a ground wire on mazdas so dont use the dimmer wire by mistake, you will burn up your rheostat (dimmer) and your dash lights will quit. To ground a radio, screw the wire to the bracket that holds the radio.
LayedOutChevy   +1y
Here's a link that shows you factory wiring codes for most vehicles.
http://www.the12volt.com/installbay/vehiclewiring/1/yeard/Mazda.html
